Processor Configurations
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Processor Configurations
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2021-09-13 04:16 AM . Last Modified: ‎2021-09-13 04:16 AM
1673
I downloaded the SecurityExpertExtension license and added it to SmartConnector but I can't see it on Processor Configurations
Replies 11
ardak
Posted: ‎2021-09-13 04:57 AM
1668
You have downloaded the license for the extension, but you still have to download and add/install the extension itself to smartconnector.
This will be one or several DLLs that have to be moved to the smartconnector installation folder. Please consult the extension documentation.
BR
Armend
Erwin-vd-Zwart
Janeway
Posted: ‎2021-09-13 05:29 AM . Last Modified: ‎2021-09-13 05:30 AM
1662
Hi Armend,
A little bit off-topic perhaps, as you mentioned certain dll's where the extention depands on need to be copied, it reminded me to ask this, i find myself sometimes struggling with determine to select the DLL's that need to be included when copying the extention to make the extention pop-up in the framework, is there a easy way to determine what dll's need to be included?
Posted: ‎2021-09-13 05:51 AM
ardak
Posted: ‎2021-09-13 06:09 AM
1654
I'm guessing you are talking about while developing an extension.
Yes, this can be a bit of a pain to find manually, but the answer would be "any DLL that is present in the extension build folder but not in the Smartconnector folder. I use a tool call "Beyond Compare", but anything that will help you find those DLLs will work.
BR
Armend
Posted: ‎2021-09-13 06:18 AM
1651
i have already inserted SecurityExpert Dll's to SmartConnector but , Unfortunately the problem still continues
ardak
Posted: ‎2021-09-13 06:33 AM
1649
What do you see when you click "Add new" ?
Posted: ‎2021-09-13 07:20 AM
1647
ardak
Posted: ‎2021-09-14 01:01 AM
1633
It looks like there is something missing with your DLLs. Please enable trace logging (Setup -> Service Settings) and restart the smartconnector service. Then attach the resulting log output.
BR
Armend
Posted: ‎2021-09-14 11:15 PM
1628
nothing has changed
ardak
Posted: ‎2021-09-14 11:20 PM
Posted: ‎2021-09-14 11:31 PM
log_file_link:  https://filebin.net/b019pncazb57afka
