Notification Id Items not found
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Notification Id Items not found
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Smart Connector
Back to SmartConnector Forum
esari
esari Schneider Alumni (Retired)
Posted: ‎2021-09-21 05:00 AM
1454
Hello
Third party company is using SmartConnector to pull data from EBO ES. Normally it will work correcty but some times there is error message in smartconnector log.
EwsConsume,user,Invalid subscription
RestServe,user,{"Message":"Notification Id Items not found"}
This can happend 10 times per day for this one third party company. What would be reason for this error message? What should I look at EBO ES?
I have attach log.txt to this post.
Esa
  • Thumbnail of Smart Connector
    Smart Connector
View products (1)
ardak
Posted: ‎2021-09-21 11:39 PM . Last Modified: ‎2021-09-21 11:41 PM
1445
Hi Esa,
This one was tricky 🙂
It seems like the integrator, probably by accident, is sending "Items" as a Notification Id to the GET /Notifications/{Id} endpoint.
Please ask them to check their code to see if there is any place this could happen.
BR
Armend
esari
Posted: ‎2021-09-22 07:31 AM
1440
Hello
I think problem is that notification ID is empty. So maybe program need to wait little bit or there is actual empty response from SmartConnector. There is no log entry for 'notification create response' when there is error.  If they are not going to get ID then they will call {{base_url}}/Notifications//Items then Smartconnector resolves that items is the ID.
Error:
2021-09-22 09:57:16.4009,Debug,RestServe,user,Notifications,Create,86FC89E9B2D1430FA54A90060A6E186B,Request,{"Item":{"SubscriptionId":"b290d476-fa3c-4a6e-844b-dd395f11cca9","ChangesOnly":false}},
2021-09-22 09:57:16.5103,Debug,RestServe,user,Notifications,RetrieveById,3E2E890FA3D3437A9128BD2DF253BF23,Request,{"Id":"Items"},
2021-09-22 09:57:16.5103,Error,RestServe,user,{"Message":"Notification Id Items not found"},
Working:
2021-09-22 09:57:16.9165,Debug,RestServe,user,Notifications,Create,BC65A2CD414D4FF497B441A350A223AC,Request,{"Item":{"SubscriptionId":"2e9eb9ec-3636-48c7-bf0e-dca2aaeb3da2","ChangesOnly":false}},
2021-09-22 09:57:16.9478,Debug,RestServe,user,Notifications,Create,BC65A2CD414D4FF497B441A350A223AC,Response,{"SubscriptionId":"2e9eb9ec-3636-48c7-bf0e-dca2aaeb3da2","CreatedOn":"2021-09-22T06:57:16.9165939Z","NotificationItemCount":50,"Id":"E2274593CC5248128314079A2F039CAA"},
2021-09-22 09:57:16.9478,Info,RestServe,user,Notifications,Create,ET=31 mSec,
2021-09-22 09:57:16.9790,Debug,RestServe,user,Notifications,RetrieveNotifications,A9B69A8C8D2543E4B62009BE005562BD,Request,{"Id":"E2274593CC5248128314079A2F039CAA","Take":200,"Skip":0},
Esa
ardak
Posted: ‎2021-09-22 11:21 PM
Hi Esa,
Not entirely sure what you're saying here, but in your logs you have it laid out clearly.
In the error example, you send in "Items" (as a string) as a Notification Id, it's not empty.
If you supply the full debug or trace logs it might give us a clue to why that's happening.
BR
Armend
