Does SmartConnector uses the Regional settings when it send Values' subscriptions?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Does SmartConnector uses the Regional settings when it send Values' subscriptions?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-09-23 12:19 PM
828
Assuming my language in the OS Regional settings is Danish, and the decimal point is a comma (","), will SmartConnector send EBO values to its SmartConnetcor clients using the comma or the "." decimal point?
For example, will it send "11,3" as the value is seen in the EBO? Or, "11.3"?
If it is always using the "." decimal point can you release a new version that considers the language in the regional settings?
Thank you.
Michael
ardak
Posted: ‎2021-09-26 09:55 PM
820
Where is your error occurring? In your code or EBO? Smartconnector (and as far as I know EBO in its EWS implementation) uses InvariantCulture. It will be using . as separator.
BR
Armend
mike_meirovitz
Commander
Posted: ‎2021-09-26 10:49 PM
818
Hi Armend,
The error is in our code. We use a Windows API to convert a string value to double. When the regional settings are Danish, the conversion from "11.3" to double will be 113 instead of 11.3 since "11.3" is not a valid number. It should be "11,3".
Changing the Regional Format to Danish also changes the default Decimal Symbol used by the OS from period to comma. Therefore, the string value containing a period does not get recognized.
The workaround we used is to convert the string "11.3" to "11,3" before we convert it to double. It is now working well but it would be nice if the SmartConnector will support the regional settings including the decimal point as comma.
Thank you.
Mike
ardak
Posted: ‎2021-09-26 11:06 PM
As I've said, EBO and Smartconnector will always use the . as a separator. It doesn't make sense to make smartconnector culture sensitive as it would introduce unnecessary problems where systems with different culture settings can't be connected.
You can read more about culture insensitive code here.
Use this:
string ewsValue = "11.3";
var converted = Convert.ToDouble(ewsValue, CultureInfo.InvariantCulture);
BR
Armend
