Multiple Parameter PUT
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Multiple Parameter PUT
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa237670_brid
sesa237670_brid Schneider Alumni (Retired)
Posted: ‎2018-03-25 05:31 AM
1120
I am using Sample REST Provider Class example to add my SetMode() method. This method takes three parameter RoomNum, mode and ModeChangeTime. I am able to add it in my custom REST Provider class. However, on execution of PUT method, I am getting error - "Can't bind multiple parameters'. Is multiple parameters supported  ? Do I need to add some attribute [MultiPostParameters]  for it to work.  Is it supported in SmartrtConnector ? Please advise.
JeffBowman
Sisko
Posted: ‎2018-03-28 06:56 AM
1
1070
Hi Neeraj,
This is actually nothing to do with SmartConnector. Programming an API controller is actually just MVC ASP stuff from .NET. As you noticed I don’t think you can have multiple parameters in a PUT request. But you can pass in an object type, instead of a 3 primitives.
See below for an example. The example has multiple URL parameters, and a single body parameter that is actually an object with a Key/Value pair.
#region UpdateValue (PUT)
/// <summary>
/// Updates the property requested to the new value.
/// </summary>
/// <param name="roomId">ID of the Alexa device targeted</param>
/// <param name="action">Action to take</param>
/// <param name="newValue">Property Name/Value pair</param>
[HttpPut, Route("Value/{roomId}/{actionName}"), ResponseType(typeof(string))]
public HttpResponseMessage Update(string roomId, string actionName, [FromBody] NameValue newValue)
Func<HttpResponseMessage> method = delegate
Func<object, HttpResponseMessage> innerMethod = delegate
var roomMapping = Provider.GetRoomMapping(roomId);
if(roomMapping == null) this.ThrowItemNotFoundException("Alexa", roomId);
var ewsId = Provider.GetValueItemId(roomMapping, actionName, newValue.Name);
var valueModel = Provider.UpdateScalarValue<ValueModel>(this, ewsId, "Value", newValue.Value);
var response = Request.CreateResponse(HttpStatusCode.OK, valueModel.Value);
return response;
return this.ExecuteAndLogCall("UpdateValue", new { RoomId = roomId, Action = actionName, NewValue = newValue }, innerMethod);
return this.ExecuteRequestAndHandleErrors(method);
#endregion
-Jeff
JeffBowman
Sisko
1
1071
Hi Neeraj,
/// <summary>
/// </summary>
return response;
#endregion
-Jeff
sesa237670_brid
Posted: ‎2018-03-28 08:12 PM
Hi Jeff,
Thanks for the explanation and sample. I am able to pass three parameters using header as in your sample:
//[HttpPut, Route("SetMode"), ResponseType(typeof(string))]
        [HttpPut, Route("SetMode/bValue/{RoomNum}/{Mode}/{ModeChangeTime}"), ResponseType(typeof(string))]
        public HttpResponseMessage SetMode(string RoomNum, string Mode, DateTime ModeChangeTime)
I found the issue is with date being passed as '1/1/2018'. It works if I pass date as '1 Jan 2018'.
Thanks Again!
Neeraj Tomar
