License upload not valid
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • License upload not valid
JeffBowman
Sisko JeffBowman Sisko
164
ardak
34
sesa180908_brid
34
mike_meirovitz
Commander mike_meirovitz
21
Back to SmartConnector Forum
mpatel_knightwa
Lieutenant | EcoXpert Master mpatel_knightwa Lieutenant | EcoXpert Master
Posted: ‎2018-04-03 11:58 AM
1170
We tried to set up the smart connector server and used a license token to generate the license for continuum alarm extension, but Smart Connector license server keep on going to the same upload license screen beside valid license upload. we have tried both the option of applying license token and manual license upload, but it's not going through.
JeffBowman
Sisko
Posted: ‎2018-04-03 12:09 PM
1
1110
Hi Mitul,
You will actually need two licenses for this to work.
  1. Smart Connector Framework License: The first one is the license for the Smart Connector framework itself.
  2. Continuum Alarms Extension License: The second one, which I believe you have already gotten by following the instructions on the Extension's marketplace space, is the one for the Continuum Alarm's extension itself. This license by itself, will not make Smart Connector run.
To get the license for #1, follow the manual steps, but instead search for "SmartConnector". See the below screenshot.
Depending on where you are installing this, select the license that pertains to you (Make sure to get the 2.3 version). The evaluation license is a 30 day license, the developers license is a 90 day license, and the Commercial is a permanent license. Follow the instructions on the screen for each, and upload this license to the SmartConnector portal. After you do that, hopefully this will fix the issue you are seeing.
Let me know!
-Jeff
JeffBowman
Sisko
1
1111
Hi Mitul,
Let me know!
-Jeff
mpatel_knightwa
Posted: ‎2018-04-03 01:02 PM
Thank you, Jeff, for the prompt response. We were able to fix the issue with your answer.
