Missing library
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Missing library
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
LucasHawk
Lieutenant JG LucasHawk Lieutenant JG
Lieutenant JG
Posted: ‎2018-02-27 11:15 AM
3
1356
Missing library
I am walking through the initial documentation, and trying to build the 'WeatherExtension'. VS is complaining to me about the following functions:
ConvertFromUnixTime
ConvertTemperature
I also am getting complaints about ‘Forecast’ and ‘CurrentConditions’ types when calling the generic ‘RequestWeatherData’ method.
I cannot find anywhere in the documentation where I build these, and when I search my libraries, nothing is found. Did I miss including something? Here are my included libraries:
using Mongoose.Common;
using Mongoose.Common.Attributes;
using Mongoose.Process;
using System;
using System.Collections.Generic;
using System.ComponentModel.DataAnnotations;
using System.ComponentModel;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Mongoose.Ews.Server.Data;
using SxL.Common;
using Ews.Common;
using System.Net.Http;
using System.Net.Http.Headers;
Is there another Mongoose or MyGet library I need to install?
I have attached my classes, and please feel free to point out what I missed if it is in the documentation (and my apologies if it is).
WeatherExtension Class.txt.zip
Tags (2)
  • documentation
  • weatherextension
sesa180908_brid
Commander
Posted: ‎2018-02-27 11:51 AM
1300
I recommend you compare your code to the completed example which can be found here: GitHub - BuildingsLabs/SmartConnectorSamples: Sample projects for SmartConnector
If you zip up your solution or just send a screen shot of the actual error message, that might help too.
LucasHawk
Lieutenant JG
Posted: ‎2018-02-27 01:09 PM
1
1300
Thanks for the reference! I did find the 'ConvertTemperature' and 'ConvertFromUnixTime' methods tucked in at the end of 'UpdateProcessor'. (It would be useful to have these added to the documentation, I think. Or can someone point to where they are defined in the current documentatio? The documentation is purported to be a walkthrough of sorts, and I was unclear if these were intended to be referencing some library i was missing...)
However, even doing some copy/pasta for every class, I still don't have the 'CurrentConditions' or 'Forecast' types created anywhere. Below is the error:
Edit:
Ok, I guess I found it in the proxy class. This was glossed over quite a bit in the documentation (bottom of page 40). Any help on where this 'Proxy' folder/class goes?
JeffBowman
Sisko
Posted: ‎2018-02-27 02:22 PM
Hi Lucas,
The folder would go in the root of your project, just make sure to change the namespace to your local namespace.
-Jeff
