Issue Logger.LogDebug
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Issue Logger.LogDebug
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa450478_brid
sesa450478_brid Schneider Alumni (Retired)
Posted: ‎2017-05-24 05:46 AM
971
Hi, i have a following problem:
I created a processor in Smart Connector, and in my code i wrote, for example (Logger.LogDebug(LogCategory.Processor,"MyString", string.Format("ExMyString"));).
But I do not see the "ExMyString" in file log (I have attach the file log).
I want to use the Logger to monitor the execution of the code.
Any idea what I do not see the debugging logs?
LogSmartConnector.txt.zip
sesa180908_brid
Commander
Posted: ‎2017-05-24 06:20 AM
The Logging stack in SmartConnector has two settings which limit what is or is not written to the log files: Logging Filters and Logging Level.  These can be edited from the SmartConnector Portal.
Logging Filters allows you to control what categories you want to allow to be written to the log files.  Refer to section 5.17 of the SmartConnector Installation and Configuration Guide for more information.
Logging Level allows you to limit how verbose log entries you want to allow to be written to the log files.  Verbosity goes from Error => Trace.  If you set the level to say Debug, then all log commands at Debug or higher will be logged.  By default, the Logging Level is set to Info which would not include Debug.  Refer to section 5.13 of the SmartConnector Installation and Configuration Guide for more information.
Adam_Summers
Lt. Commander Adam_Summers Lt. Commander
Lt. Commander
Posted: ‎2017-05-24 06:40 AM . Last Modified: ‎2022-10-18 10:24 PM
This post may also be helpful if you're missing logging from unit tests. https://community.se.com/message/92822?commentID=92822#comment-92822
