Is it possible to transfer smartconnector license to another PC or virtual machine
SmartConnector Forum
Showing results forΒ
Did you mean:Β
  • EcoStruxure Building
  • SmartConnector
  • Is it possible to transfer smartconnector license to another PC or virtual machine
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
YangboLIU
Captain YangboLIU Captain
Captain
Posted: β€Ž2019-03-19 06:56 PM
1933
Customer purchase a smartconnector license and installed, they want to transfer smartconnector on another pc or a virtual machine, is it possible to transfer the license without buy a new license? If yes, how to do it? Need return the license first?
Thanks and Best Regards
Yangbo
Adam_Summers
Lt. Commander Adam_Summers Lt. Commander
Lt. Commander
Posted: β€Ž2019-03-20 01:45 AM
1929
Hi Yangbo,
There is potentially more than one license you could have a problem with here.
I would suggest in all instances I hope the license providers can help although I'm not sure it's covered fomally in any documents. There is no mechanism to formally return a license, so you will just have to claim new ones.
1) SmartConnector Runtime - as long as you have a valid purchase order for the original license, I would suggest just claiming a new license from the License Depot for the version you require and enter your purchase order number again. I'm sure the team working on the backend will notice that this is an upgrade. This process does not issue any new charges so you won't get an invoice for getting a new license.
2) For any licensed extension, they are also likely tied to your machine thumbprint. So again, you'll need to claim again, contact the developers of the extensions and in my opinion they should in this instance grant you another claim on your license claim token. I know that for my team (Global Engineering Centre of Excellence) if you have any extensions licensed by us and this type of incident happens we would be happy to help you transfer you license. This would however be up to the developers of the extension, so if you have extensions from partners or other SE developers you will need to check with them. This is just my opninion not fact πŸ™‚
Replies 4
Adam_Summers
Lt. Commander
1930
Hi Yangbo,
YangboLIU
Captain
Posted: β€Ž2019-03-20 02:05 AM
1927
Hi Adam
Thanks for your answer, I got it. but I have further question, if the machine destoryed or reinstall the OS,  Get a new license is the only soultion?
Best Regards
Yangbo
Adam_Summers
Lt. Commander
Posted: β€Ž2019-03-20 02:35 AM
For the runtime, I would say yes, you'll need to claim a new license.. for the extensions you can ask the developer to reissue the same license at it is all stored in the license portal backend. So for any licenses which have been claimed from my tenant on the system I can issue the original license back to you. It would be locked to the same machine thumbprint so as long as there are no hardware changes the license should still be valid. If there is a hardware change, it's likely the thumbprint would change meaning you will need a new license.
Adam_Summers
Lt. Commander
Posted: β€Ž2019-03-20 02:35 AM . Last Modified: β€Ž2019-03-20 02:36 AM
Β
