Is it possible to generate an alarm using REST APIs?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Is it possible to generate an alarm using REST APIs?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2018-09-27 10:19 PM
776
Is it possible to generate an alarm using REST APIs? For example: "This alarm was generated via REST API".
Note: the alarm is not defined in the EBO.
Thanks.
Mike
JeffBowman
Sisko
Posted: ‎2018-10-18 11:36 AM
764
Hi Michael,
It is not possible to trigger an alarm directly. But if you configure an alarm in EBO, and then know which value of a Value object will trigger it, you can set the value of that Value object and effectively trigger an alarm.
-Jeff
JeffBowman
Sisko
765
Hi Michael,
-Jeff
mike_meirovitz
Commander
Posted: ‎2018-10-19 12:29 PM
Thank you Jeff!
