Error: The HTTP request is unauthorized with client authentication scheme 'Digest'
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Error: The HTTP request is unauthorized with client authentication scheme 'Digest'
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2018-11-11 11:05 PM
891
We get the following error when  we start our SmartConnector extension:
2018-11-12 08:56:32.5444,Error,Processor,<no principal>,EBO Alarm Item Discovery Processor,System.ServiceModel.Security.MessageSecurityException: The HTTP request is unauthorized with client authentication scheme 'Digest'. The authentication header received from the server was 'Digest realm="ews@SxWBM",qop="auth",nonce="3D0FE37C53C78542AE0AE8F508B8682B",opaque="811407"'. ---> System.Net.WebException: The remote server returned an error: (401) Unauthorized.
at System.Net.HttpWebRequest.GetResponse()
at System.ServiceModel.Channels.HttpChannelFactory`1.HttpRequestChannel.HttpChannelRequest.WaitForReply(TimeSpan timeout)
--- End of inner exception stack trace ---
Any idea what may be the problem?
Thank you.
Michael
JeffBowman
Sisko
Posted: ‎2018-11-12 06:45 AM
891
Hi Michael,
This error most likely points to that invalid user credentials are being used when trying to communicate with EBO. Can you verify that the Smart Connector extension is using the correct credentials (try and log into EBO with them).
-Jeff
JeffBowman
Sisko
892
Hi Michael,
-Jeff
mike_meirovitz
Commander
Posted: ‎2018-11-12 09:07 AM
Thank you Jeff!!!
