Posted: 2018-01-10 07:08 AM
I've been able to get subscriptions and notifications to work for getting value items out of struxureware, but it doesn't seem to work for alarms.
Currently, I'm sending something like this:
POST /Subscriptions/Create
"DurationInMinutes":10,
"SubscriptionType":"ValueItemChanged",
"Ids":[
"02/OrangeJuice/minitest/MyAlarm"
The alarm is not included in the results when I Create/Get the first Notification for the Subscription.
I also tried setting SubscriptionType = AlarmItemChanged, and this didn't seem to work.
Hi Josh,
SBO as an EWS server does not support alarms via subscription. You will need to use the /AlarmEvents endpoint (with its query parameters) to retrieve alarm events.
-Jeff
Hi Josh,
As a 'Work Around', if it is an SBO alarm you could always use the ID '11/OrangeJuice/minitest/MyAlarm/AlarmState' with the 'ValueItemChanged' event type in order to see when the AlarmEvent changes. (0 = Normal, 1 = Alarm, 2 = Acknowledged, 3 = Reset, 4 = Disabled). That said, doing it this way, you will only ever see the most recent change for that alarm.
Typically, if you want to track the AlarmEvents, using the /AlarmEvents endpoint is generally the best to do.
-Jeff
