Hi all!
I have created a SmartConnector which requires you to create some "Mappings" of Building Operation points. In order to do this, I have added a List<IotDeviceMap> (see below for C# code) to my processor which should then be able to be populated via the SmartConnector UI.
However, When I click on the "Plus" sign at the side to add a new Mapping, SmartConnector hangs and just continuously shows the "Working" popup as below:
The "Mappings" class is as follows:
[Required]
public IotDevice DeviceSettings { get; set; }
public EnterpriseServerIoTProcessor()
DeviceSettings = new IotDevice
Config = new IotDeviceConfig(),
Mappings = new List<IotDeviceMap>
new IotDeviceMap()
Has anyone experienced anything similar? I am running the latest version of SC, 2.3.108.
Thanks in advance!
Mark
The workaround for 2.3.108 is as described above (using List<string> instead of string[]). However, this is actually a bug in SmartConnector as both string[] and List<string> should be valid for a configuration. A bug has been written internally and a fix will be worked on!
-Jeff
Hi Mark,
Can you also post the code for the IotDevice, IotDeviceConfig, and IotDeviceMap class itself (Feel free to send them to me privately as well).
One thing to check is that these classes implement 'ITraversable'.
-Jeff
Hi Jeff,
Please see below...
using System.Collections.Generic;
namespace ISC.Iot.Common.Models
public class IotDevice
private List<IotDeviceMap> mappingsField;
public IotDeviceConfig Config { get; set; }
public List<IotDeviceMap> Mappings
get => new List<IotDeviceMap>(mappingsField);
set => mappingsField = value;
public class IotDeviceConfig
public string DeviceId { get; set; }
public string ESAddress { get; set; }
public string ESUsername { get; set; }
public string ESPassword { get; set; }
public int ESPort { get; set; }
public class IotDeviceMap
public string FullPointPath { get; set; }
public string PointType { get; set; }
public string[] TriggerValues { get; set; }
Hi Jeff,
Just tried adding ITraversable to IotDeviceMap and get the same results...
Mark
Hi Mark,
Another thing I am not sure about is the use of string[] TriggerValues. Can you try changing this to List<string>?
-Jeff
For anyone else having a similar issue, Jeff Bowman has managed to find a root cause for this.
In the Class "IotDeviceMap" a string Array is used for "TriggerValues". If you change this for a List<string>, everything will start working!
Thanks Jeff Bowman
Mark
-Jeff
