GetItemsItems() - the description is returned empty
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • GetItemsItems() - the description is returned empty
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-10-03 12:04 AM
694
We are trying to get the alarm's description using the GetItemsItems API. However, the description is returned empty. See the code below.
Any idea what is the problem?
foreach (var alarmEvent in result.DataRead)
var alarmItem = alarmItems.GetItemsItems.AlarmItems.FirstOrDefault(a => a.Id == alarmEvent.SourceId);
var value = values.GetItemsItems.ValueItems.FirstOrDefault(a => a.Id == alarmItem?.ValueItemId)?.Value;
var Description = values.GetItemsItems.ValueItems.FirstOrDefault(a => a.Id == alarmItem?.Description)?.Value;
Logger.LogTrace(LogCategory.Processor, this.Name, alarmEvent.ToJSON());
Logger.LogTrace(LogCategory.Processor, this.Name, Description);
if (!apiClient.SendAlarmEvent(alarmEvent, value, Description).Result)
_prompts.Add(new Prompt { Message = $"Failed to send alarm event with ID {alarmEvent.SourceId} and state {alarmEvent.State} to UCME", Severity = PromptSeverity.MayContinue });
Thank you.
Mike
ardak
Posted: ‎2021-10-03 10:09 PM . Last Modified: ‎2021-10-03 10:48 PM
should probably be
var Description = values.GetItemsItems.AlarmItems.FirstOrDefault(a => a.Id == alarmItem?.Id)?.Description;
