'DataAdapter ' definition problem
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • 'DataAdapter ' definition problem
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2021-10-04 01:26 AM
1004
  'DataAdapter' does not  contain  a definition  for belows , how can i fix this problem 1.PNG2.PNG
ardak
Posted: ‎2021-10-04 03:56 AM
That looks right.
You're probably getting "DataAdapter" from somewhere else. Check if you need all your references (a quick search shows that "DataAdapter" exists in "System.Data.Common". Remove this reference or rename your DataAdapter property.
BR
Armend
ardak
Posted: ‎2021-10-04 02:47 AM
1000
What error are you getting? Also, please show where the DataAdapter is declared.
Posted: ‎2021-10-04 03:38 AM
998
ardak
That looks right.
BR
Armend
