Alarm Push processor - can we get the alarm's Description?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Alarm Push processor - can we get the alarm's Description?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-09-12 10:19 AM
3344
We have a SmartConnector Push processor that receives alarms in real-time from the EBO. The question is:
Can this processor receive the alarm's Discovery property from the EBO?
See the attached screen capture of the class we are suing.
Thank you.
Mike
mike_meirovitz
Commander
Posted: ‎2021-10-01 01:24 AM
3302
Hi Armend,
Thank you. I shall mark this as a solution. Can you add the "Note 1" and "Note 2" to the EWS in the future?
Thanks.
Michael
Replies 14
ardak
Posted: ‎2021-09-13 01:07 AM
3335
From what I understand from your screenshot, you are using the AlarmItemReader, which in turn uses the GetAlarmEvents and GetUpdatedAlarmEvents EWS endpoints. These get the AlarmEvents, and not the AlarmItems. If you are looking for the alarms Description property, you'll have to make an additional call(GetItems), fetching the AlarmItem, to get the property.
BR
Armend
mike_meirovitz
Commander
Posted: ‎2021-09-28 09:29 AM
3331
Hi Armend,
Thank you for your answer. Can we also get the alarm's 'Note 1' and 'Note 2' using the GetItems API?
Thank you.
Mike
mike_meirovitz
Commander
Posted: ‎2021-09-28 11:03 AM
3328
Hi Armend,
I am trying the Swagger in SmartConnector to get the alarm's Description, Note 1 and Note 2.
I have the following alarm ID:
02-Server 1-MyValues-Building-10thTemp Out of Range Alarm
After URL Encode it is:
02-Server%201-MyValues-Building-10thTemp%20Out%20of%20Range%20Alarm
Can you point me to the right API in the Swagger?
Thanks.
Mike
ardak
Posted: ‎2021-09-28 09:48 PM
3326
It's GET /Values/{Id}/Description
You cannot get Notes as it is not part of EWS.
BR
Armend
mike_meirovitz
Commander
Posted: ‎2021-09-28 10:02 PM
3324
Hi Armend,
I have tried it and got an error 404. Please see the attached file.
Any idea what is the problem?
The alarm ID is: 02-Server 1-MyValues-Building-10thTemp Out of Range Alarm
After URL Encode it is: 02-Server%201-MyValues-Building-10thTemp%20Out%20of%20Range%20Alarm
Thank you.
Mike
ardak
Posted: ‎2021-09-28 10:52 PM
3322
If the EWS server is an EBO system, your ID looks wrong.
It should be in this format:
02/Server 1/Example Objects/Test Alarm
mike_meirovitz
Commander
Posted: ‎2021-09-30 05:42 AM
3317
Hi Armend,
Thank you for your answer. Can our discovery processor get the Alarm Description, Note 1 and Note 2?
Currently our alarm discovery processor discovers these properties:
Alarm-ID
Alarm Presentation (Message) - Above Upper limit message / Below lower limit message
Above Upper limit Priority
Below Upper limit Priority
Thank you.
Mike
ardak
Posted: ‎2021-09-30 07:57 AM
3315
I don't think you can get the Notes through EWS.
You can get the Description with your processor using the EWS client.
mike_meirovitz
Commander
Posted: ‎2021-09-30 08:15 AM
3314
Hi Armend,
Thank you for your answer. I didn't see any API to retrieve the Above Upper limit Priority and Below Upper limit Priority but our processor is able to retrieve (using the source I sent you).
Similarly, can we retrieve the other fields during the discovery? (Notes and Description)
Thanks.
Mike
ardak
Posted: ‎2021-09-30 08:25 AM
3312
I believe Notes cannot be retrieved. Description can be fetched with GetItems, not with GetValues, which the chunk of code you sent me is using.
mike_meirovitz
Commander
Posted: ‎2021-09-30 08:53 AM
3310
Hi Armend,
Thank you for your answer. Can you please point me to the documentation of the GetValuesItems API?
Thanks.
Mike
ardak
Posted: ‎2021-10-01 12:16 AM
3307
This is the EWS spec. This is what the Smartconnector client uses and the GetValues request is in there too.
mike_meirovitz
Commander
3303
Hi Armend,
Thanks.
Michael
ardak
Posted: ‎2021-10-01 01:29 AM
This is unfortunately not in my control, but I'll talk to the dev team behind EWS to see if it's possible.
BR
Armend
