Hi Jeff,
I have upgraded my SmartConnector Update processor to version 2.4.7. FindOrCreateProcessorValue api is throwing run time exception before it was working in old version. Please advise.
My code:
ProcessorValue _processorValueLastUpdate = this.FindOrCreateProcessorValue(ApplicationDefinitions.CMMSLastUpdate);
Exception --- {"Object reference not set to an instance of an object."}
Source - "Mongoose.Common”
StackTrace " at Mongoose.Common.Data.ExtensionMethods.FindOrCreateProcessorValue(IProcessorValueHelper helper, String key, String group, String aggregate, DataPointValueType valueType)\r\n at SmartConnector.Extension.CMMS.UpdateProcessor.Execute_Subclass() “
Thanks!
Neeraj Tomar
THis was looked into and the issue was because the Unit test project in Visual Studio was still using the Mongoose.Process.Test NuGet package that was deprecated in version 2.3. Once the new Mongoose.Test project was used, this issue went away.
