EBO Value discovery
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • EBO Value discovery
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-10-13 11:55 PM
1343
EBO Value discovery
Our SmartConnector discovery processor discovers all EBO Values(points). When the values are discovered, we see different kinds of prefix. For example: 11 and 01. See below.
11/Server 1/ConfigDBSize
01/Server 1/MyValues old/Analogs/Analog 1
Can you tell me what is the difference between "11" and "01"? Are there any other prefixes? Can I get a list of all possible prefixes and their meaning?
And another question: what about Function Blocks? Are they discovered the same way EBO values are discovered? Or, should we do a "special discovery" for Function blocks?
Thank you.
Mike
ardak
Posted: ‎2021-10-14 12:41 AM
1331
If you remember from your thread Function block programs are a type of container and the points contained are values of that container, in this case with a 11 prefix.
BR
Armend
Replies 5
ardak
Posted: ‎2021-10-14 12:01 AM
1339
Heres a thread explaining:
EWS prefixes
BR
Armend
mike_meirovitz
Commander
Posted: ‎2021-10-14 12:09 AM
1335
Hi Armend,
Thank you for your answer. What about my second question? See below.
Thank you.
Mike
ardak
1332
BR
Armend
mike_meirovitz
Commander
Posted: ‎2021-10-14 01:49 AM
1327
Thank you Armend,
I asked this question because in the past we were told by Jeff Bowman that Function Blocks have different discovery approach.
Now we understand that it is not required.
Regads,
Mike
ardak
Posted: ‎2021-10-14 01:52 AM
It is slightly different, as you'd maybe not expect the 11 prefix on a value on a container, if that's what Jeff referred to. You'd have to keep that in mind.
BR
Armend
