Can you please explain how can I create these items in the EBO?
02 = Alarm Item
12 = Value Item that is a property of an Alarm Item
22 = Alarm item that is a property of another Alarm item
32 = History Item that is a property of an Alarm item
03 = History Item
13 = Value Item that is a property of an History Item
23 = Alarm item that is a property of a History item
33 = History Item that is a property of an another History item
I want to check how the EBO item discovery is working if I have such items.
Thank you.
Mike
Our SmartConnector processor includes an option to do a partial discovery. This is done by defining a folder (path). For example: "00/Server 1/TEST6".
When using partial discovery, the results are incorrect.
We need to create the items above (02,12,22,...) to see what do we get as a response to the discovery processor.
Currently I don't see the way to create these objects in the EBO. See the attached screen capture.
Thank you.
Mike
Thank you.
Mike
What results are incorrect? In which way?
02 = Alarm Item
Is an EBO alarm
03 = History Item
Is an EBO Trend log.
These are the ones you'll usually find.
Not sure about all the rest, they usually show up as 11, but there may be special cases.
