Hi all!
I would like to know if anyone has had experience with this integration of EBO + Digital Lumens, I would also like to know if there are guide documents on how to do it and what is required, I think it would be with the Smart Connector (SXWSWSCDL100001) but I have doubts if it is just that what is necessary or if you should also consider any of the WS (SXWSWGWSX00001, SXWSWEWSX00003, ...)
I appreciate your support, please, thanks!
https://www.digitallumens.com/resources/case-study/schneider-electric-saves-lighting-energy-costs/
That said, the Smart Connector extension isn't generally available as it was just a proof of concept. We could send it to you, and what documentation we have, but it would come with no support, as it is more or less currently unsupported.
If you are interested, please send me and email jeff.bowman@se.com.
Best Regards,
-Jeff
Best Regards,
-Jeff
Hi Jeff,
Actually we are trying to do this integration with the existing documentation, but we have the following problem when validating the processor configuration:
I think there might be an aditional license to run this processor especifically for this smartconnector.
You are correct, there is.
I have just made this license public for download on https://www.smartconnectorserver.com/Marketplace in the License Depot: Look for the one called Digital Lumens Proof of Concept.
Best Regards,
-Jeff
Thank you Jeff,
We will continue with the procedure and let you know the results.
Regards.
OSG.
Hi, just to let you know, the integration worked as explained in the documentation.
Thanks for the support.
Regards
