Do I need to delete the EWS server interface in the EBO after I have added/removed ValueItems using the setup processor?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Do I need to delete the EWS server interface in the EBO after I have added/removed ValueItems using the setup processor?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2020-11-06 01:33 AM
1043
Do I need to delete the EWS server interface in the EBO and redefine it after I have added/removed ValueItems using the setup processor?
Currently, after I delete or add value items using the Setup processor, the EBO shows the previous ValueItems tree.
Can the EBO sync with the EWS server to see the updated picture of the ItemValue tree?
Thank you.
Mike
JeffBowman
Sisko
Posted: ‎2020-11-06 07:19 AM
1040
Hi Michael,
If you want to 'add' items, then you can just 'host' objects again.
However, if you have items that you know were deleted, if you want them to be removed the EWS Interface, you have 2 options. Delete them manually from the interface OR delete all hosted items (you don't need to delete the whole interface, just all the objects) and then reshost.
Of course deleting all the objects, if they are bound and used with EBO already will cause issues as all this configuration will need to be redone, so this should be avoid unless required.
Best Regards,
-Jeff
JeffBowman
Sisko
1041
Hi Michael,
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2020-11-06 08:42 AM
Thank you Jeff!
