Does Enterprise Server require extra license to connect to SmartConnector?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Does Enterprise Server require extra license to connect to SmartConnector?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2017-11-21 02:45 AM
3938
As I understood we can connect Enterprise Server to SmartConnector using EWS. Does ES requires EWS License or is it included in the SmartConnector License? I am having some trouble knowing the exact extra cost in licenses necessary to develop a solution, so that I can make a business plan.
Brad_S
Captain Brad_S Captain
Captain
Posted: ‎2017-11-22 05:36 AM
3783
The info provided above is correct.  When using Smart Connector, you do not need to license EWS.  The only license fee for the Smart Connector is the deployment license (SXWSWSCDL100001)    Smart Connector should be part of the "white list" of connections like those indicated in PA-00349.
Replies 12
JeffBowman
Sisko
Posted: ‎2017-11-21 06:36 AM
3769
Hi João,
As far as I know, you do not need the EWS license for SBO if you use SmartConnector.
Bradley Stradtmann​ can you confirm?
-Jeff
Posted: ‎2017-11-22 03:12 AM
3769
That would be the logic choice and if so we don't need to buy the SXWSWEWSX00001 license.
And what about using a SmartConnector Process to access directly Enterprise Server using EWS?
Miguel_Angelo
Lieutenant Miguel_Angelo Lieutenant
Lieutenant
Posted: ‎2017-11-22 04:37 AM
3769
Hello João
You must have SXWSWEWSX00001. To connect SBO to SmartConnector you must create EcoStruxure Web Service.
Best Regards
Miguel Gonçalves
Miguel Gonçalves
sesa180908_brid
Commander
Posted: ‎2017-11-22 05:09 AM
3769
In the context of SmartConnector (i.e you are using EwsClient or IManagedEwsClient in a SmartConnector based integration) it has always been my understanding that you do NOT need an EWS license - its usage is superseded by the SmartConnector license - which you DO need for commercial deployments.
Bradley Stradtmann can confirm?
Benji
Administrator Benji Administrator
Posted: ‎2017-11-22 05:15 AM
I can't imagine anyone would claim that a SBO EWS license of any sort would be needed...
But I think you should look into getting this PA-00349 updated to include SmartConnector: Search - Asset Library | EcoBuilding - The Exchange
Brad_S
Captain
3784
Benji
Posted: ‎2017-11-22 05:39 AM
3769
Any idea who we could get to update the PA? David White​ ?
Posted: ‎2017-11-22 05:49 AM
Yep, likely be me. I will start that process on Monday after the holiday.
Posted: ‎2017-11-22 08:02 AM
3785
Thank's All!
I simply let the discussion run because I noticed that this wasn't very clear inside the Schneider commercial strategy. It's a new product and it is understandable.
But for what I notice now I can also deduce that we can also connect to Enterprise Server data and historical trend log using EWS, using for example a Processor Class. Is that true?
João Ferreira
sesa180908_brid
Commander
Posted: ‎2017-11-22 08:41 AM
3785
Yes.  you can connect to any EWS Server from a Processor subclass (using EwsClient or IManagedEwsClient).  There are also Reader classes in the Mongoose.Process.Ews namespace that wrap the EWS "messiness" (see ValueItemReader, AlarmItemReader, HistoryItemReader, and SubscriptionReader) to make your life easier.
Alternatively, you can use the RESTful EWS Gateway to front any EWS Server (using the SoapEwsRestProvider) or SBO natively using the SboEwsRestProvider (the latter being available in v2.3 of SmartConnector).  Consumption of that could be from any web client (including perhaps a Processor subclass).
Posted: ‎2017-11-22 10:20 AM
3785
My question is more related to Enterprise Server Licensing and not SmartConnector (using EwsClient).
The SW-EWS-3:
Because it is being accessed from a SmartConnecter Process it doesn't need licensing right?
sesa180908_brid
Commander
Posted: ‎2017-11-22 10:42 AM
That is correct.
