Does EWS or SmartConnector Support Multiple Connections?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Does EWS or SmartConnector Support Multiple Connections?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
JessieSu
Lieutenant JessieSu Lieutenant
Lieutenant
Posted: ‎2023-04-03 08:30 PM
1550
Is it possible to install 20 sets of SmartConnector as RESTful EWS Gateway connected to one EBO ES server?
- Does EBO EWS support multiple connections from SmartConnectors?
If a SmartConnector set as RESTful EWS Gateway and connected to an EBO ES server, is it possible to share the data/trend records to 20 sets of other system?
- Does SmartConnector support multiple connections?
We are preparing the training which include SmartConnector installation and setting as RESTful EWS Gateway, and sharing data to other systems. Asking these questions for preparing the training environment. Thank you!
BRs/Jessie
SteveGregory
Commander SteveGregory Commander
Commander
Posted: ‎2023-04-04 05:34 PM
1511
Yes that will work, however, in a real world application, it will most likely bottle neck if you are polling a lot of data. You can also have one REST endpoint with multiple clients and it will create separate managed clients to EBO for each REST client, but that too will bottle neck with 20 clients. But it will work.
SteveGregory
Commander
1512
JessieSu
Lieutenant
Posted: ‎2023-04-05 06:32 PM
1492
Thank you @SteveGregory
JessieSu
Lieutenant
Posted: ‎2023-04-05 06:59 PM . Last Modified: ‎2023-04-05 07:00 PM
Add an information, I think real projects should follow the following restrictions:
