I am using SmartConnector version 2.5.5. From time to time the SmartConnector service is stopped. I can see this event in the event viewer.
The SmartConnectorService service terminated unexpectedly. It has done this 3 time(s).
The SmartConnector log file is attached.
Any idea what is the reason?
Thanks.
Mike
If you are using it as a REST API for EBO or and EWS server, do you have multiple REST clients and are you seeing a lot of managed clients in the status window? Curious because i had a similar issue.
Yes. We are using REST API and EWS Server.
