gSoap communication error
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • gSoap communication error
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
ND7KR
Crewman ND7KR
Crewman
Posted: ‎2023-04-02 11:54 PM
1517
Hello.
When I am trying to send a message websocket server I am taking "
Communication
SOAP-ENV:Receiver."http://schemas.microsoft.com/net/2005/12/windowscommunicationfoundation/dispatcher":InternalServiceFault
CWS Client Plugin
12
The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the <serviceDebug> configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework SDK documentation and inspect the server trace logs." error. Here the scenario :
EBO clients can change the values. If change will happen customSetValuesProcessor will send message to websocket server.
Do u have any idea why am I getting this error?
Thanks for your answer in advance.
ND7KR
Crewman ND7KR
Crewman
Posted: ‎2023-04-05 11:54 PM
I changed my method and algorithm and problem solved. If you have this error check the methods are proper.
ND7KR
Crewman ND7KR
Crewman
