Container Id maximum length
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Re: Container Id maximum length
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
  • Intelligent Devices Forum
Back to SmartConnector Forum
Anonymous user
Not applicable
Posted: ‎2020-02-28 11:41 AM
1220
I'm using an EndPoint SoapEwsRestProvider to get some data from an ES. Everything is working fine except with some Containers that I cannot browse.
For ex, for the container with the id:
00/GTB - SERM/Servers/Serveur Neos_Lazard/1 AS Neos Lazard/1.2- Communication/1.2.2- Réseau IP/Interface Modbus Client TCP/PowerTag - Groupe a Absorbtion/Modbus Signals/Device Configuration Advanced
If I try the request:
/Containers/00%252FGTB%2520-%2520SERM%252FServers%252FServeur%2520Neos_Lazard%252F1%2520AS%2520Neos%2520Lazard%252F1.2-%2520Communication%252F1.2.2-%2520R%25C3%25A9seau%2520IP%252FInterface%2520Modbus%2520Client%2520TCP%252FPowerTag%2520-%2520Groupe%2520a%2520Absorbtion%252FModbus%2520Signals%252FDevice%2520Configuration%2520Advanced/Children?type=Container
I have the error:
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request - Invalid URL</h2>
<hr><p>HTTP Error 400. The request URL is invalid.</p>
</BODY></HTML>
The problem is probably the length of the id (or of the url) because if I remove some chars, it works.
Is it a known limitation ?
Thank you.
Replies 2
JeffBowman
Sisko
Posted: ‎2020-02-28 12:02 PM
Hello!
This is not something I have heard about, I will look into it and see if it is someone on the REST gateways end that can be fixed.
Thank you for bringing this to our attention. I will update when I find something out.
Best Regards,
-Jeff
JeffBowman
Sisko
Posted: ‎2020-02-28 12:41 PM
Hi!
So I did some digging and this issue actually seems to be an issue with the default Windows "UrlSegmentMaxLength" parameter. This defaults to 260. Since the ID of an object is contain in a URL segment, and your ID is longer than 260, you are receiving this error.
In order to change it, you need to add a registry key at HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\HTTP\Parameters
type: DWORD
Value:  0 - 32,766  (I did 1000 in my test)
Once you add this registry key, restart your computer, and it should work. You can find more info about how to add this key in the below link.
https://support.microsoft.com/en-us/help/820129/http-sys-registry-settings-for-windows
Let me know if you run into any problems.
Best Regards,
-Jeff
