Compile Time Error in Updgrade
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Compile Time Error in Updgrade
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa237670_brid
sesa237670_brid Schneider Alumni (Retired)
Posted: ‎2018-09-05 07:22 AM
1000
Hi Jeff,
When I Update my old smartconnector extension from V2.2.130 to V2.4.7, I am getting few complie time error.  One of the error is in below code. This code snippet is to get the Id of running update processor:
using (var db = MongooseObjectFactory.Current.GetInstance<IProcessConfigurationDataSource>())
                    IQueryable<ProcessConfiguration> updateProcessorConfig = db.ProcessConfigurations.Where(x => x.Name == ApplicationDefinitions.UpdateProcessorName);
                    ProcessConfiguration updateProcessorConfigVal = updateProcessorConfig.FirstOrDefault();
  if (updateProcessorConfigVal != null)
                        updateProcessorId = updateProcessorConfigVal.Id;
ERROR -- CS1061 'IProcessConfigurationDataSource' does not contain a definition for 'ProcessConfigurations' and no extension method 'ProcessConfigurations' accepting a first argument of type 'IProcessConfigurationDataSource' could be found (are you missing a using directive or an assembly reference?)
##Where should I find the correct method? What is the best practice to do code lookup to replace obsolete/change methods usage ?
Thanks!
Neeraj Tomar
JeffBowman
Sisko
Posted: ‎2018-09-05 07:53 AM
1
992
Hi Neeraj,
In this case what you are looking for is 'db.Items' instead of 'db.ProcessConfigurations'.
With the addition of Endpoint Configurations along with Processor Configurations in 2.3 there were some refactoring done in the core with regards to these interfaces.
In general, if an overload is obsoleted it is marked, but in this case since the whole interface changed, this was not done. So, in this case, your best bet to figure out the new link would have been to inspect the definition of IProcessConfigurationDataSource and then see IDataSource and look at that as well.
-Jeff
JeffBowman
Sisko
1
993
Hi Neeraj,
-Jeff
sesa237670_brid
Posted: ‎2018-09-05 08:26 AM
That helped ! Thanks.
