C-Bus Schedule Plus - SmartConnector Logs v 2.0.11
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • C-Bus Schedule Plus - SmartConnector Logs v 2.0.11
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Chris_154851
Lt. Commander Chris_154851 Lt. Commander
Lt. Commander
Posted: ‎2018-01-18 02:18 PM
1306
I am trying to locate the log files for the SmartConnector. I have logged into the SmartConnector portal and increased the logging level verbosity to “All”, “Trace” was not in the list. I am wondering if this is related to the version I am running?
I have version 2.0.11 installed.
According to the documentation I have read the logs should be located in “%ProgramData%\SmartConnector\Logs”, unfortunately this folder does not exist, I am also wondering if this is also version related?
I have managed to find some logs in a different location but not really sure if this is the right one. “C:\ProgramData\Schneider Electric StruxureWare\Building Operation 1.9\S2ConnectAgent\Logs” SE.SBO.S2ConnectESAgentLog.txt
I have attached a couple of screenshots as well. If anyone is able to shed some light on this that would be great.
2018-01-19 07_53_57-MindaWrkStn - TeamViewer - Free license (non-commercial use only)-sesa154851.png
2018-01-19 07_58_06-MindaWrkStn - TeamViewer - Free license (non-commercial use only)-sesa154851.png
Tags (3)
  • c-bus
  • scheduleplus
  • v2.0.11
JeffBowman
Sisko
Posted: ‎2018-01-18 02:23 PM
1
1273
Hi Chris,
The logs that you found are not the SmartConnector logs, but for SBO's S2 connect.
Since you are using a much older version of SmartConnector, if you can, can you see if "C:\Logs" contains anything like what you need. I seem to remember at some point (maybe SmartConnector 2.1) the log directory changed from something very generic to something more explicit (C:\ProgramData\SmartConnector\Logs).
-Jeff
JeffBowman
Sisko
1
1274
Hi Chris,
-Jeff
Chris_154851
Lt. Commander
Posted: ‎2018-01-22 01:04 PM
I found this was configured in the Mongoose.Service.exe.config file,
<rollingDateFileLogger name="debugFileLogger" isInsistent="true" formattedFileName="c:\Logs\SmartConnector_{timestamp:MM-dd-yy}.log" />
