Get Containers Children using the SBO REST Provider
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Get Containers Children using the SBO REST Provider
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
PaulBates
Ensign PaulBates Ensign
Ensign
Posted: ‎2018-01-12 08:08 AM
1001
I seem to be having an issue using the SBO REST Provider when connecting to an ES and trying to retrieve information from the connected AS's.
In Swagger I can see the root folders using   GET /Containers/{id}/Children
but when I then search for information from the Automation servers via the ES
eg
http://localhost:8087/Containers/%252fESName%252fServers/Children
it does not appear to return the correct ID and I'm unable to retrieve information from the AS's using this get request.
When the SBO REST Provider connects directly to the AS the GET /Containers/{id}/Children
all works fine.
Please can you help?
JeffBowman
Sisko
Posted: ‎2018-01-18 02:10 PM
Hi Paul,
SmartConnector 2.3.109 was just released, which contains the fix for this bug. It is available at www.smartconnectorserver.com for download.
-Jeff
JeffBowman
Sisko
Posted: ‎2018-01-12 01:12 PM
961
Hi Paul,
Seems you have run into a bug with the new SboEwsRestProvider. I have entered this as a bug! Look for a new version of SmartConnector sometime next week with this fix .
-Jeff
PaulBates
Ensign
Posted: ‎2018-01-15 04:55 AM
Thanks Jeff
JeffBowman
Sisko
Hi Paul,
-Jeff
