Configuring email settings
Setting up ITA
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA installation and setup
  • Setting up ITA
  • Configuring email settings
  • Mark as Read
  • EcoStruxure IT forum
EcoStruxure IT Support
Request Support
Back to Setting up ITA
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-14 08:34 AM
In System Setup > Email Settings, you can configure email settings to allow the IT Advisor server to send predefined email notifications.
Once you have configured these settings, you can set up the system to send automatic notifications on work order changes.
For the primary Simple Mail Transport Protocol (SMTP) server, then for the backup server, if required, specify:
  1. The email "From" address that will identify the emails that are sent by the IT Advisor server.
  2. The SMTP server information needed by the IT Advisor server for communication:
    1. Port number at the SMTP server used for communication with the IT Advisor server and secure connection for the communication, if required.
    2. Logon credentials for the SMTP server that the IT Advisor server must use to logon to the SMTP server, if required.
      Note: Enable this option only when using an SMTP server that requires logon access.
0% helpful (0/1)
Didn't find what you are looking for? Ask our Experts
