pilot cold water with sun
  • pilot cold water with sun
David_SE
Captain David_SE Captain
148
Alfred_SE
24
Maude.wiser.
22
Altar
Crewman Altar
Crewman
Posted: ‎2025-06-03 10:32 AM
430
hi,
I've installed an automatic system that should work in theory.
A hot water tank is switched on when the exported energy exceeds 2kw.
No ‘when’ condition.
The tank starts up but always stays on, even though the energy is less than 2kw.
Does manual mode override automatic mode?
Or have I misunderstood how the automatic mode works?
Thank for answer
  • Energy devices
David_SE
Captain
Posted: ‎2025-06-09 04:48 AM
hi @Altar ,
Thanks for your post, you forgot to add a condition in your automatism such as "OFF when exported energy below than 2KW".
Manual mode overrides automatic mode.
If you have Wiser Home with a WH Hub 2nd Gen and you monitor your grid & solar energy, you can try Wiser AI that control automatically your hot water tank according to your needs.
BR
David
David_SE
Captain
hi @Altar ,
BR
David
