Wiser Smart Thermostat application note
  • Wiser Smart Thermostat application note
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
sesa386114_brid
sesa386114_brid Schneider Alumni (Retired)
Posted: ‎2018-03-07 08:29 AM . Last Modified: ‎2022-02-11 04:59 AM
1
1188
For proper functionality and long battery life it is necessary to keep these installation rules
1) Wiser Smart Controller shall not placed beside wi-fi router
2) Thermostat shall be on place where customer can see status of device
3) All devices in the system must be properly commissioned - H-relay cannot be alone in a zone. Always with Thermostat
4) Controller must be ON all time. If necessary to switch off then batteries from Thermostat need to be removed
5) Mains-powered Wiser Smart devices must retain ON all the time as they work also as Zigbee signal extenders (H-ACT, L-ACT, SmartPlug). If there is active any 3rd party system switching off power branches, this must be deactivated.
7) Keep in mind distance between battery and socked-powered devices. Walls, ceilings or floors significantly reduce zigbee signal strength.
  • Temperature Control
  • eer51000
  • thermostat
  • wiser smart
Posted: ‎2019-11-22 06:54 AM
Thanks for sharing this with the community !
Have a nice day.
Have a nice day.
