Could we implement a panic button system with Wiser II?
  • Could we implement a panic button system with Wiser II?
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
sesa8875
sesa8875 Schneider Alumni (Retired)
Posted: ‎2014-04-08 08:41 PM
3
1363
In Indonesia it is quite common to have panic button as part of security system for landed villas.
sesa96364
sesa96364 Schneider Alumni (Retired)
Posted: ‎2014-04-21 07:05 PM
There are typically 2 functions that need to be executed when a panic button is pressed:
- lights all on
- automatically call for help
As the Wiser can directly interface with a MinderPro alarm system this device can be used to automatically notify someone of an emergency.
The Wiser can be used to trigger a scene to turn on all lights.
The panic button could be triggered from the alarm panel or the Wiser app alarm widget.
The following logic code example would cause a C-Bus scene to be executed when a panic alarm is triggered.
once GetBoolIBSystemIO("Security Panic") then
  SetScene("Panic Scene");
Posted: ‎2014-04-16 08:47 PM
Depends on how you need your panic button to function, if just send out I/O telegram, should be fine.
Posted: ‎2014-04-17 12:45 AM
Wiser 2 would able to link minderpro security system and there is serveral of input can be use for panic button, dry contact input which show status from minderpro widget.
sesa96364
- lights all on
