Wiser Home App version for MacBook etc.?
Showing results forΒ
Did you mean:Β
  • Wiser Home App version for MacBook etc.?
David_SE
Captain David_SE Captain
144
Alfred_SE
24
Maude.wiser.
22
bgt432
Ensign bgt432
Ensign
Posted: β€Ž2024-05-17 04:46 AM
6
2671
Cannot seem to find a non-mobile or iPad based version.
  1. Does one exist?
  2. If not, is there a 3rd party (free) piece of laptop based software that can be used to interface with the hub and control TRV and hot water schedules / boost / temp settings?
  • About Wiser
  • Apps
Maude.wiser.
Lieutenant
Posted: β€Ž2024-05-21 05:45 AM
2620
Hello, how are you doing? πŸ™‚
We do not have any laptop version I apologise! What do you want to see more in details?
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: β€Ž2024-05-24 01:33 AM
As LGo44 said the only option would be to use Home assistant. this is free if you already have a server or computer to run it on. I have it set up on a server at home and can access all information on my destop PC or laptop.
you could install it on your Macbook if you have no other option and then run it each time you open the Laptop but that would be too much of a PITA for my liking.
Regards Brian
(Hub 2, 15 TRV's, 2 rooms stats and 3 extenders)
Replies 6
bgt432
Ensign bgt432
Ensign
Posted: β€Ž2024-05-21 12:26 AM
Perhaps should have been more specific; non-mobile or non-iPad based version.
Maude.wiser.
Lieutenant
2621
lgo44
Lieutenant | EcoXpert Master lgo44 Lieutenant | EcoXpert Master
Posted: β€Ž2024-05-21 11:37 PM
A solution should be to use home assistant on a raspberry pi and the wiser integration...
https://www.home-assistant.io/
https://github.com/asantaga/wiserHomeAssistantPlatform
bgt432
Ensign bgt432
Ensign
Posted: β€Ž2024-05-22 07:38 AM
In response to Maude.wiser.
It's not more detail, but at home, a Macbook is a much better user interface and our chosen medium. I only use iOS via a 'phone if I absolutely have to - I find the difference between "mobile" and "static" platforms extremely frustrating; therefore only use the 'phone away from home. A recently bought iPad is just as terrible a thing to use as a 'phone...
But clearly I'm in the minority and will have to adapt........
BrianT58
Lieutenant BrianT58
Lieutenant
Regards Brian
asdsadasdsasdasasd
Crewman asdsadasdsasdasasd
Crewman
Posted: β€Ž2025-05-14 12:10 AM
The iOS App will install on MacOS if you have an M1/2/3-based laptop, by the way.
No difference in the UX except for some slightly improved resizing behaviour, but at least no faffing with the phone.
