Thermostat help - Schneider TC303 with Empower
  • Thermostat help - Schneider TC303 with Empower
David_SE
Captain David_SE Captain
143
Alfred_SE
24
Maude.wiser.
22
renra
renra
Cadet
Posted: ‎2024-07-02 04:14 AM
752
Hi, my 1bhk apartment has Schneider TC303 controller. The issue I am facing is: Setting the cooling temp to 28 degrees, the room temperature continues to drop in the living room, meanwhile the bedroom is not that cold.
Any ideas on this what could be the fault and what could be a short term or long term fix.
Speed Test https://vidmate.bid/
  • Temperature Control
Maude.wiser.
Lieutenant
Posted: ‎2024-11-11 08:37 AM
How are you doing ? I was wondering if you could contact our technical support as it seems to be a bug: 0333 6000 622 or support@schneider-electric.zendesk.com
Thanks in advance,
Maude.wiser.
Lieutenant
Thanks in advance,
