Open window detection: does it actually work!?
  • Open window detection: does it actually work!?
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
jjmaestro
Crewman jjmaestro
Crewman
Posted: ‎2024-02-04 04:20 AM
3085
When I open the windows, I see a sharp drop in temperature in the TRVs under those windows. Immediately, I see the demand % shoot up and the radiators heat to max in a few minutes:
"Open Window Detection" is set to ON for those TRVs (well, for ALL my TRVs) yet it seems to not work. The previous temp is "pretty flat" i.e. it's easy to see that there's a sudden drop in temperature that has nothing to do with the room unless a ton of cold air came in.
So, what gives?
  • Temperature Control
David_SE
Admiral
Posted: ‎2025-04-24 11:37 PM
No feedback from user => post closed.
Don't hesitate to create a new one if you face on unexpected behaviour / questions.
BR
David
Replies 9
Maude.wiser.
Lieutenant
Posted: ‎2024-05-21 08:45 AM
2969
How are you doing ? I was wondering if you could contact our technical support as it seems to be a bug: 0333 6000 622 or support@schneider-electric.zendesk.com
Thanks in advance,
Fozzie1960
Ensign Fozzie1960
Ensign
Posted: ‎2024-05-21 10:36 PM
In response to Maude.wiser.
It’s never worked on my system either.
jjmaestro
Crewman jjmaestro
Crewman
Posted: ‎2024-05-23 03:54 AM
Sure, happy to contact them. Let's hope it can be fixed...
Maude.wiser.
Lieutenant
Posted: ‎2024-11-11 03:03 AM
2541
Hello 🙂
No news from your side for a while, did you call the support ? Did it change something?
Regard,
jjmaestro
Crewman jjmaestro
Crewman
Posted: ‎2024-11-12 12:19 PM
Hi, sorry, I'll try to get back tomorrow with more data.
jjmaestro
Crewman jjmaestro
Crewman
Posted: ‎2024-11-13 03:08 AM
I've tested this again and it's still happening... 9 months and zero work on this? I mean, it's not like it's hard to reproduce what's going on!
I'll try to call technical support but I shouldn't be wasting time on this. This is YOUR problem, your product sells with "open window detection" and it clearly doesn't work. Please fix it.
jjmaestro
Crewman jjmaestro
Crewman
Posted: ‎2024-11-13 03:37 AM
2514
Yeah, I emailed back in May / June I think? I've called them again, re-explained everything and re-sent the last image I've uploaded to the email ticket (Request #201404 in Zendesk I think, and new ticker number is #215878).
So... hopefully someone will look into this because it's clearly not working. The "open window detection" is clearly FAKE, as it's easy to see that the demand kicks in the moment the TRV temp crosses the TRV target temp.
There's ZERO "intelligence", no algorithm that e.g. calculates the rate of temp drop and/or has some "intelligence" regarding the average heat loss of the room, etc.
Let's see if they "fix" it (i.e. IMPLEMENT it) because the advertised functionality clearly states that:
And here's what CItizens Advice has to say about misleading customers into buying something:
David_SE
Admiral
Posted: ‎2025-03-29 12:14 AM
In response to jjmaestro
Hi @jjmaestro ,
I just read your post, is the reported issue still present with our last Wiser releases ?
If yes, are you able to share here the ticket number provided by our technical support ?
Thanks.
BR
David
David_SE
Admiral
BR
David
