HubR loses connection then all data; power-on gives orange setup and green heating LEDs.
Showing results forΒ
Did you mean:Β
  • HubR loses connection then all data; power-on gives orange setup and green heating LEDs.
David_SE
Admiral David_SE Admiral
152
Alfred_SE
24
Maude.wiser.
22
madbilly
Ensign madbilly
Ensign
Posted: β€Ž2024-10-13 02:31 PM
1275
Hi all,
Recently moved to a new house with a combi boiler rather than the system boiler with heating+hot water zones at our old house. Rather than fudge using our two-zone Wiser HubR I decided to buy a secondhand one-zone HubR for use with combi boilers - these details might not be relevant but I mention them anyway.
Unfortunately this HubR loses Wifi connection after a while and the only way to reconnect it is by re-inputting the Wifi credentials, but then it appears to have lost all data and I need to add all the devices again and set up all the rooms again, etc.
The only odd thing about this HubR is that when it turns on the setup LED is orange and the heating LED is green, and they stay like that for several minutes, before the HubR goes into first-use mode and I have to connect to the local Wifi AP it has, and do the setup etc. If I turn off the power to the HubR then turn it on again, I get the orange setup and green heating LEDs stuck on again. I can't find this LED combination in any documentation, so is this a sign that the HubR is faulty in some way?
Cheers πŸ™‚
  • Temperature Control
madbilly
Ensign madbilly
Ensign
Posted: β€Ž2024-10-30 11:27 AM
Drayton have asked me to return the unit for investigation so it seems that it's faulty.
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: β€Ž2024-10-15 02:05 AM
1247
hopefully thius may help, if not give them a call they were really quick in solving my issue.
Wiser HubR LED Behaviour Guide – Drayton By Schneider Electric (zendesk.com)
Regards Brian
(Hub 2, 15 TRV's, 2 rooms stats and 3 extenders)
madbilly
Ensign madbilly
Ensign
Posted: β€Ž2024-10-16 01:26 AM
In response to BrianT58
Hi Brian,
Thanks, yes this is what I meant when I said I can't find this LED combination in the documentation - that help sheet doesn't show a solid amber setup LED.
Cheers πŸ™‚
madbilly
Ensign madbilly
Ensign
Β
