HubR disconnects every 6 minutes
  • HubR disconnects every 6 minutes
David_SE
Captain David_SE Captain
149
Alfred_SE
24
Maude.wiser.
22
Carlnrtn
Crewman Carlnrtn
Crewman
Posted: ‎2024-01-20 02:57 PM
1457
  • Hi,
Hopefully someone can help here because I'm totally at a loss.
My HubR is dropping every 6 minutes. It's connected via WiFi with signal of -52. Very little interference on the 2.4Ghz, my scanner doesn't pick up any other SSIDs.
It has a reserved IP via DHCP with a lease timer of 2 hours.
Every 6 minutes, on the dot, it drops out. Continuous ping running and it will lose about 5 pings before reconnecting. It is not disconnecting from the WiFi network.
I have run a packet capture, and can see it stops responding to pings, it initiates 802.1x (why? This isn't configured on my network) and then I see it broadcast a DHCP discover.
It's like it's just dropping its IP address.
I've tried factory reset, I've tried tweaking all kinds of settings on my network. Still I can't get it to stay stable. No other devices on my wireless have any issues like this.
It's a massive shame users don't have the ability to view logs from the device itself.
Is anyone able to offer any advice on this?
  • Temperature Control
Carlnrtn
Crewman Carlnrtn
Crewman
Posted: ‎2024-02-05 03:20 AM
In response to nischaypond
Apologies for late reply. I've managed to sort it.
I ran some packet captures and could see every minute the device was sending a ping to 1.1.1.1 and it's local gateway. My firewall blocked any ping/http/https access to the local gateway, so it was failing 5 pings to the local gateway and on the 6th attempt it reset the TCP/IP stack. I opened up ICMP to the Wiser on the firewall and it's been stable ever since.
nischaypond
Ensign nischaypond Ensign
Ensign
Posted: ‎2024-01-23 01:23 AM
1442
Hi @Carlnrtn  could you please give me your MAc address to check and also raise a support case with your local Wiser customer support? They can help you replace the device if it's faulty.
Carlnrtn
Crewman Carlnrtn
Crewman
