Flourescent light support for drop ceiling
  • Flourescent light support for drop ceiling
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
KThompson
KThompson
Cadet
Posted: ‎2025-01-22 11:58 AM
759
Good Morning.
I am installing fluorescent lighting in my basement drop ceiling (24in x 24in standard panels) and need a way to support a diffuser, or use another light type, for the fluorescent light. The light and ballast are the Home Depot type and mount into the ceiling joists above the drop ceiling. The drop ceiling aluminum grid is a 24" x 24" square grid and I do not have a 24" x 48" diffuser to put into the opening to support the width.
PDF diagram attached.
All suggestions are welcome.
Thank you.
Kirk Thompson
  • Lighting
David_SE
Admiral
Posted: ‎2025-03-25 12:26 AM
hi @KThompson ,
Thanks for your post but i'm not able to answer to your request, i recommend you to contact the shop and/or the lights supplier. BR David
David_SE
Admiral
hi @KThompson ,
