Posted: 2024-12-17 03:26 AM . Last Modified: 2024-12-17 10:57 PM
Why does the Wiser Schneider App not support Light toggle when pressing the same Wiser Push button more times.
User case:
and so on ...
This is a very basic feature with high UX value. I'd like to have it added to the App ASAP.
And while we are at it: Please also add Long-press support, so that short-press on Push Button triggers one action and a long-press another action.
Basic features that should have been supported already
Posted: 2025-04-01 02:23 AM
hi @dannyvdpoel & @christian91 ,
Thanks for your post, in the Wiser Home system / application, the light control is working as you said even if it is not a toggle.
Please find below two app screenshots.
BR
David
Posted: 2024-12-22 02:21 PM
Is there any solution to this? This is a very basic feature which i am in desperate need of.
A toggle function to add to buttons in touch3 should be the number one priority to be added asap. For use in the app of course..
BR
David
Posted: 2025-04-01 05:41 AM
@David_SE this is not a solution to my problem.
I would like to have a physical button (Moment) toggle between a specified light turning On & Off every time you press the same button. Of course this should be programmable via the App. Today it isn't.
Its a standard and very basic feature required in any smart home.
Example of a SE wiser battery switch with 4 buttons shown here. Technically I would like a switch like this to toggle up to 4 different light sources On & Off via the 4 buttons.
Posted: 2025-04-02 01:14 AM
This is not an adeqate solution to my problem either.
I want to control my garage door via the touch app on my phone. To trigger the garage door opener i need a button to send a pulse, not to stay active after pressing. I can not find a button with this function.
There should be a "pulse option" e.g for the main switch symbol.
Do you have any ideas?
Christian
