Darkmode (Day/night display mode)
Showing results forΒ
Did you mean:Β
  • Darkmode (Day/night display mode)
David_SE
Captain David_SE Captain
149
Alfred_SE
24
Maude.wiser.
22
JohannesL
Crewman JohannesL
Crewman
Posted: β€Ž2024-06-25 01:56 AM . Last Modified: β€Ž2024-07-10 06:31 AM
2475
It would be highly diserable to have a darkmoder or day/display mode for the Wiser App. It is really disturbing to be blinded by the bright display when using the Wiser app in darkness. Ideally this setting should follow the phone display mode. Wiser is one of the few app's that that doesn't already have this feature.
  • Apps
  • User Testimonials
JohannesL
Crewman JohannesL
Crewman
Posted: β€Ž2024-11-11 08:04 AM
In response to Maude.wiser.
I'm living in Sweden. What is the reason for using different apps in different regions? As a share holder I find this a waste of resources I must say.    And as a user in I find it rather confuring and unuserfriendly.
David_SE
Captain
Posted: β€Ž2025-04-02 11:59 PM
In response to JohannesL
Hi @JohannesL , "soon" is in 2025. The development of Wiser by SE is not stopped, we just deployed a new version on iOS. Stay connected !
Replies 10
Fozzie1960
Ensign Fozzie1960
Ensign
Posted: β€Ž2024-06-25 10:45 PM
2438
Dark mode or System Default can be set in Settings/App Theme.
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: β€Ž2024-06-26 01:08 AM
In the Wiser App the dark moide can be set in the app under "App Theme" you can choose Light, Dark or Sytem default which does as you request.
Regards Brian
(Hub 2, 15 TRV's, 2 rooms stats and 3 extenders)
JohannesL
Crewman JohannesL
Crewman
Posted: β€Ž2024-06-27 09:56 AM
In response to Fozzie1960
2415
Is this in IPhone or Android? I am using Android and cannot find any App Theme in Setting.
Best Regards
Johannes
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: β€Ž2024-06-28 01:38 AM
2402
This is on an android phone App version is 6.10.1 (build 1654) it's in settings then at the bottom there is "app theme" in there you should find Light, Dark or Sytem default
Regards Brian
JohannesL
Crewman JohannesL
Crewman
Posted: β€Ž2024-06-29 04:18 AM
In response to BrianT58
2364
Strange. Are we using the same app? I am using "Wiser by SE". Version 9.118.1. There is no AppTheme under settings or anywhere else either as far I can see.
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: β€Ž2024-07-02 02:30 AM
Ah now that is probably the issue. Wiser by SE is not available in my region (UK) and so I'm using Wiser Home maybe @Maude.wiser. can advise further.
Regards Brian
Maude.wiser.
Lieutenant
Posted: β€Ž2024-11-11 07:55 AM
2105
Hello @JohannesL where are you based? Wiser by SE is in the Nordics, Spain and Australia!
You will also have the possibility to switch to Wiser home soon πŸ˜‰ with AI algorithm, Solar Panel connected to the app, Dark mode for sure!
JohannesL
Crewman JohannesL
Crewman
JohannesL
Crewman JohannesL
Crewman
Posted: β€Ž2025-03-30 12:24 PM
1584
Hi @Maude.wiser. ,
 I am living in Sweden. When is "soon"?  It seems like development of Wiser by SE have stopped the app was last updated in August 24.
David_SE
Captain
Β
