Condition delay
  • Condition delay
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
Camellian_nz
Camellian_nz
Cadet
Posted: ‎2024-06-16 07:53 PM
809
Condition delay
I have a fan in a toilet wired to a wiser switch along with the toilet light on a separate switch, I want to set a automation when IF the toilet light has been on for 1 minute the action turns on the fan, IF the light hasn't been on for 1 minute and is switched off then the fan does not come on. I cant see how to create this automation, any help with this?
  • Apps
  • Lighting
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: ‎2024-06-18 01:21 AM
Unfortunately I'm fairly certain the Wiser App isn't able to do what you need. It will allow you to set a schedule for each switch but not turn one on depending on the use of another.
This is something you could probably do in a 3rd party product like Home assistant, as that allows duration based events across multiple devices.
Regards Brian
(Hub 2, 15 TRV's, 2 rooms stats and 3 extenders)
BrianT58
Lieutenant BrianT58
Lieutenant
Regards Brian
