Continue
  • My Subscriptions
  • Events
Can a Wiser TRV Be Opened & Closed Without Calling for Heat
  • Can a Wiser TRV Be Opened & Closed Without Calling for Heat
David_SE
David_SE Mentor
214
Alfred_SE
Alfred_SE Leader
24
Maude.wiser.
Maude.wiser. Contributor
22
IS7
IS7
Explorer
Posted: ‎2024-12-29 12:41 PM
2542
Hi All
I have an undersized radiator in my lounge because of this the room would tend to be cool.
I have removed the Wiser TRV so the radiator comes on whenever another TRV is calling for heat.
99% of the time this works really well but sometimes the lounge gets too hot.
I wondered if it is possible to set up a Wiser TRV so that it would open and close around a temperature set point but disable the heat call to the boiler from this TRV just to prevent the room overheating.
I could close down the manual valve to limit water flow but that would affect the heat output at times when full heat was required.
Ian
  • About Wiser
  • Temperature control
David_SE
David_SE Mentor
Mentor
Posted: ‎2025-03-26 08:13 AM . Last Modified: ‎2025-03-26 08:14 AM
In response to Dave_G
2231
Hi @Dave_G and @IS7 ,
A new release was just deployed yesterday. That feature is not yet available but be integrated in the next releases excepted later that year.
BR
David
Replies 5
David_SE
David_SE Mentor
Mentor
Posted: ‎2025-01-31 12:42 AM . Last Modified: ‎2025-03-13 01:37 AM
2427
Hi @IS7 ,
Thanks for your feedback and the behaviour you want to have on your installation.
In the coming releases of the Wiser Home, you will be able to decide whether a heat demand on a room will trigger the boiler or not.
What is your hub & app version ? Do you try to add a Wiser iTRV without connection to a Wiser hub channel in the room channel ?
Thanks.
David
Dave_G
Dave_G
Explorer
Posted: ‎2025-02-25 03:25 PM . Last Modified: ‎2025-02-26 07:09 AM
In response to David_SE
2351
Hi @David_SE
Do you know when this new release will be available please ?
The latest update was on 16th Jan 2025.
Please advise.
I also have the same problem, some of my rooms have undersized radiators so I would prefer to open and close trv without calling for heat.
David_SE
David_SE Mentor
Mentor
2231
BR
David
Rudi84
Rudi84
Explorer
Posted: ‎2025-08-08 12:53 AM
Hi has this feature been released yet? And is it available in the UK and Ireland?
Rudi84
Rudi84
Explorer
Posted: ‎2025-08-23 12:56 AM
@David_SE has the feature been released in Ireland?
