CCTFR6700 WISER 16A RELAY FOR TEMPERATURE CONTROL
  • CCTFR6700 WISER 16A RELAY FOR TEMPERATURE CONTROL
David_SE
Captain David_SE Captain
139
Alfred_SE
24
Maude.wiser.
22
BrianT58
Lieutenant BrianT58
18
Eric975
Crewman Eric975
Crewman
Posted: ‎2025-06-11 05:51 AM
381
I have an issue with the installation of this device. Although the pairing operation with the Hub (2nd generation) was successful, the menu for selecting the floor probe is not displayed.
The relay option is correctly selected. The firmware version of the relay is 1.8.12, and a room thermostat has been paired for the same room.
The Schneider Home app version is 7.2.0 (build 197540). The Hub is up to date. The selected location is France.
Could someone help me resolve this issue?
Thank you.
  • Communicating Actuators and Energy Valves
Eric975
Crewman Eric975
Crewman
Posted: ‎2025-07-22 06:52 AM
In response to David_SE
Hi David, everything works fine now with the update. Really appreciate your support. Cheers
David_SE
Captain
Posted: ‎2025-07-22 06:15 AM
281
Hi @Eric975 ,
Thanks for your post. Sorry for the delay in the answer. Do you face on the same issue with the last version of Wiser Home ?
I attached below a screenshot with the last WH app version, pay attention that if the control type is "fil pilote", the "floor sensor" is not displayed.
BR
David
Eric975
Crewman Eric975
Crewman
