Posted: 2024-11-18 02:03 PM
So....I'm getting a bit fed up with the system I have. I have a hub, a room thermostat and rad valves. I will often only heat parts of the house, controlled by the room stat in one of the rooms. I will often boost the heating when I want it via the app rather than using the schedule.
I also go away for work for short periods when I don't want any heating in the house and so I set the temp to a low value (5.5 deg) and the 'Follow schedule' option off. But I have found, on several occasions - the latest just today - that the room stat is set to a 'high' temperature when I am away. I have wondered whether I have set the thing by mistake myself. BUT on this occasion I am absolutely certain that it is not something that I have done. As I left home three days ago I checked all the settings and the temperature set for the room stat was 5.5deg. This evening I looked at the app and the room stat was set for 17.5 deg - so I may well have been heating half an empty house for the last three days. I don't call that a very smart system!
Does anyone else experience this behaviour from the app or other parts of the system? Can anyone explain what is going on?
Many thanks for any input.
Posted: 2025-04-04 09:16 AM
Hi @Gazza ,
Sorry to that late answer on your post.
We apologize for your unexpected behaviour seen with Wiser. Did you contact also the local customer support ? Is your system run as you want ? I will close the post but if the issue is still present, please reopen one !
BR David
Hi @Gazza ,
BR David
