Sensor plots in IT Expert
Reporting
How to create and save sensor plots and view the reports and assessments available in EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Reporting
  • Reporting
  • Sensor plots in IT Expert
  • Mark as Read
  • How to graph multiple sensors
  • Add a sensor plot to a dashboard
  • How to share a sensor plot
EcoStruxure IT Support
Request Support
Back to Reporting
  • Mark as Read
Picard EcoStruxureIT
‎2019-04-08 07:42 AM
Last Updated: Sisko JLehr Sisko ‎2025-09-15 08:40 AM
Go to the Devices page to select sensors and save your sensor plot.
Click the menu icon in the tile to Delete the sensor plot report or Configure report options to schedule emailed reports.
Create a sensor plot
To create a sensor plot from a device:
  1. Select a device on the Devices page.
  2. Click the Sensors tab. Select the sensors you want to plot. Use quotes to filter lists by exact phrase, for example, "phase 3"
    You can click the star to mark sensors as a favorite, create thresholds on sensors, and toggle Display thresholds configurations to see sensors that have thresholds configured.
  3. Click the toggle to see sensors that have thresholds configured. Click Configure new threshold to create a threshold on a sensor.
    To compare sensors, click Compare sensors... on the Devices tab. Select the devices you want to compare, and then click Compare. You can then select the sensors you want to plot from the list for each device.
  4. Click Plot sensors.
    Select Sensor and then toggle Highlight threshold zones to see sensors that have thresholds configured.
    Hover to view details for data points on the graph.
    For numeric sensors, view sensor metrics in a table below the graph, including: Units; Last known value; Minimum, Maximum, and Average value; Delta by value and by time.
  5. Select the timeframe you want to see. You can plot sensors for one hour up to 365 days or choose a custom date range. Six hours is the default.
    Sensor history goes back to February 2022 and will continue to increase over time to a maximum of 4 years.
    Note: Sensor history for EcoStruxure Ready Smart-UPS that use the SmartConnect port to connect starts in October 2022 and will continue to increase over time to a maximum of 4 years.
  6. Select Split graph by to split the graph by sensor or unit.
  7. Select Zoom to fit to see variations in the data in more detail.
  8. Select Save to save the sensor plot on the Reports page.
  9. Select Add to dashboard to add a widget directly to a dashboard.
    Note: When you create a widget on the dashboard, you can display sensor data for up to 30 days.
To configure thresholds on multiple devices, see Configure alarm thresholds for notifications.
Schedule a sensor plot report
  1. Go to the Reports page > Sensor plots.
  2. Select a tile to view the sensor plot report, and then click Configure report options to schedule a daily, weekly, or monthly emailed report.Cory_McDonald_4-1745924511256.png
    Note: To schedule a report directly from the report tile on the Sensor plots tab, click the menu icon on the tile and click Configure report options.
  3. Toggle Send scheduled report to view configuration options.
  4. Specify how often you want the report to be sent; the units, language, and time zone; and the email address of at least one recipient. You can also change the report name if needed.
  5. Click Save to save the report as a scheduled report, or click Save as new to save a new report as a scheduled report and keep the original report as non-scheduled.
See also
Share a sensor plot
