How to graph multiple sensors
Reporting
How to create and save sensor plots and view the reports and assessments available in EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Reporting
  • Reporting
  • How to graph multiple sensors
  • Mark as Read
  • Sensor plots in IT Expert
  • Add a sensor plot to a dashboard
  • How to share a sensor plot
EcoStruxure™ IT Expert
EcoStruxure IT Support
Request Support
Back to Reporting
  • Mark as Read
Sisko JLehr Sisko
‎2024-01-25 09:49 AM
  1. On the Devices page or on the Alarms > Active alarms page, click Compare sensors...
    Note: On the Active alarms page, you must sort the list by device to compare sensors.
  2. Select the devices you want to compare, and then click Compare.
  3. Select the sensors you want to plot from the list for each device and click Plot sensors.
    Note: You can toggle the Display threshold configuration to see whether the sensors you selected have thresholds configured in IT Expert.
You can hover over the graph to highlight the sensor in the list and see datapoints.
For numeric sensors, view sensor metrics in a table below the graph, including: Units; Last known value; Minimum, Maximum, and Average value; Delta by value and by time.
Select the timeframe you want to see. You can plot sensors for one hour up to 365 days or choose a custom date range. Six hours is the default.
Sensor history goes back to February 2022 and will continue to increase over time to a maximum of 4 years.
Note: Sensor history for EcoStruxure Ready Smart-UPS that use the SmartConnect port to connect starts in October 2022 and will continue to increase over time to a maximum of 4 years.
Select Split graph by to split the graph by sensor or unit.
Select Zoom to fit to see variations in the data in more detail.
Click Save to save the sensor plot on the Reports page.
Click Add to dashboard to add a widget directly to a dashboard.
Note: When you create a widget on the dashboard, you can display sensor data for up to 30 days.
