error in SCADAPack Workbench 6.6.8a installation while downloading vs_sioshell from Microsoft
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • error in SCADAPack Workbench 6.6.8a installation while downloading vs_sioshell from Microsoft
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Kourosh
Crewman Kourosh
Crewman
Posted: ‎2023-02-05 08:37 PM
2662
Hi
When running the SCADAPack Workbench setup on Windows10 21H2 , the installer times out on downloading "Visual Studio 2013 Isolated Shell".  I found the installer for "Visual Studio 2013 Isolated Shell " in "SCADAPack E IEC 61131-3 Workbench and Utilities - 8.19.1\SCADAPack_E_DVD_8.19.1\Workbench\Prerequisites\Visual Studio 2013 Isolated Shell" and ran it in an attempt to install the package independently but I get an error saying "Windows Program Compatibility is on. Turn it off and try Setup again". I checked the program compatibility and it does not seem to be on. Does anyone know what might  be causing this and how to go about fixing the issue.
Thank you in advance,
Kourosh
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Kourosh
Crewman Kourosh
Crewman
Posted: ‎2024-02-18 07:41 PM
In response to mhoovergwa
It took us a while but we managed to find the issue. This error happens because the VS installers have not been named correctly. To get around this issue:
Rename  the two files in “\SCADAPack_E_DVD_8.19.1\Workbench\Prerequisites\Visual Studio 2013 Isolated Shell” from:
Microsoft Visual Studio 2013 Isolated.exe
KB VS12-KB3107629.exe
To:
vs_isoshell.exe
VS12-KB3107629.exe
respectively.
After the files have been renamed, run each of them separately to install the VS shell.
Then run setup.exe from SCADAPack E IEC 61131-3 Workbench and Utilities - 8.19.1\SCADAPack_E_DVD_8.19.1 and run Install SCADAPack E util and Workbench.
Joel_Weder
Captain
Posted: ‎2023-02-06 08:14 AM
Hello Kourosh,
This appears to be an issue that our Tech Support team should get involved in. To get their contact information, go to se.com and select the Support menu, then click Contact Support. After you choose your region or country you will see methods to contact your regional Tech Support team.
Joel Weder
Remote Operations Specialist
mhoovergwa
mhoovergwa
Cadet
Posted: ‎2024-02-15 02:51 PM
2019
Was this issue ever resolved? because I'm having the same problem
Kourosh
Crewman Kourosh
Crewman
To:
vs_isoshell.exe
VS12-KB3107629.exe
respectively.
