Configuring MB_SERIAL_MASTER
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Configuring MB_SERIAL_MASTER
Joel_Weder
Captain Joel_Weder Captain
90
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
MartinChartrand
Captain MartinChartrand Captain
15
TKrushel
Crewman TKrushel
Crewman
Posted: ‎2024-03-27 08:08 AM
1543
I have been attempting to establish a serial Modbus communication link between a 470 and a 334 using a MB_SERIAL_MASTER function block.  No object or address will connect to the MB_DATA pin in the MB_SERIAL_MASTER block. The HELP ON TYPE for this part of the block seems quite perplexing stating that there should be nothing connected to the input pin for a WRITE command and nothing on the output pin for a READ command. With no connection to the MB_DATA pin, the block will build, load, run, and display a SUCCESS message when triggered. Without a destination, however, it is not useful. What am I missing?
  • Logic
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
TKrushel
Crewman TKrushel
Crewman
Posted: ‎2024-04-02 06:23 AM
I get to answer my own question! Turns out I am quite stubborn so I continued to work on this problem until I reached resolution. Help on Type instructions for the MB_DATA input and output pins have, unfortunately, been swapped. You do INDEED need to connect an array to the MB_DATA output pin to provide a destination when reading data from another station. Similarly, an array with source information must be connected to the MB_DATA input pin when writing data. And borrowing heavily from the Holy Hand Grenade sketch by Monty Python, the array size shall be 125. It shall not be 124. 126 is right out.
TKrushel
Crewman TKrushel
Crewman
