Why won't the AVGMV Block work?
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Why won't the AVGMV Block work?
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
SWC
Crewman SWC
Crewman
Posted: ‎2023-05-15 11:50 AM
1311
I am trying to use the AVGMV function block and it doesn't seem to be working. The RDY Output will never go Green saying it is ready to buffer. I have tried to restart the 474 has stated in the help file but still doesn't want to work
  • Logic
SWC
Crewman SWC
Crewman
Posted: ‎2023-05-15 11:52 AM
1310
Joel_Weder
Captain
Posted: ‎2023-05-15 01:11 PM . Last Modified: ‎2023-05-15 01:14 PM
In response to SWC
I've replicated the AVGMV block as you're using it, though without the logic above to generate the input value. Instead I'm simply using an analog input directly, scale 0...10000 and of type Real. The AI is tied to a physical 0...5v source. As I vary the input I can see the average or "Y" output quickly follow. The Ready or "RDY" output goes true after a few moments of operation, no issues at all.
In the AVGMV help I see this text: "NOTE: This function block performs an internal initialization in the first program cycle after a warm start or cold start (e.g. application download or power cycle) of the PLC program. Due to this, you have to make sure that the function block is invoked in the first program cycle. In case of inkoving the function block in a later program cycle, the internal initialization will not be performed and the ouputs may deliver wrong values."
Is it possible that some other logic not shown prevents this logic section from running on first scan of the
application? That's the only thing I can think of right now. If that's not the problem, you may want to contact Tech Support to discuss this.
To find the Tech Support contact information for your region, go to se.com, open the Support tab then select "Contact Support." Choose your region and you'll be provided with contact details.
Joel Weder
Remote Operations Specialist
