Unable to utilize RemoteConnect MasterIP FB
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Unable to utilize RemoteConnect MasterIP FB
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
RemoteConnect for the SCADAPack x70
MQuin777
Ensign MQuin777
Ensign
Posted: ‎2023-03-16 06:54 PM
1372
I'm attempting to use the Get master ip FB in RC and am noticing a difference between IT and the function blocks that I was using in Workbench.  See examples of both:
Workbench 6 with master register addressWorkbench 6 with master register address
RC MasterIP-no master register address definition seenRC MasterIP-no master register address definition seen
The remote connect MasterIP does not appear to have a way to set the master IP register.  Is there another way to set it?  I need to use it instead of a modbus scanner as you can see in the snapshot.
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Replies 4
Joel_Weder
Captain
Posted: ‎2023-03-17 10:44 AM
1360
Hi El_Gallo,
In Logic Editor, select the function block, then press F1 to open the Help topic for the FB. In the Help topic is a table listing and explaining all the inputs and outputs of the FB. The IP input is used to specify the server address - the address to be polled for the data. Below that is the port #.
The Help on this FB states that the IP input is a string value, so you might enter something like '192.168.2.100'  (notice the single quotes used around the IP address are required)
Joel Weder
Remote Operations Specialist
MQuin777
Ensign MQuin777
Ensign
Posted: ‎2023-03-17 01:34 PM . Last Modified: ‎2023-03-17 01:35 PM
In response to Joel_Weder
1348
Thanks Joel.  I don’t think that this answers my question though:  I need to know how to set the Master starting REGISTER not the IP address.  Example:  I want 16 modbus slave/server registers starting at 7401 polled using Enron modbus protocol into modbus master/client modbus starting address 41521.
Joel_Weder
Captain
Posted: ‎2023-03-17 01:59 PM
In response to MQuin777
1344
Ahh OK... I saw "master IP" and missed the word "register".  The REG_ADDR input is used to specify the Modbus registers in the server device, along with NUMREGS to set the quantity.  But more to your question, the output, if multiple words, is placed into an array tied to the MB_DATA output. If 16 or fewer booleans it can go into an INT variable.
NOTE that the output of a Read block is not inherently tied to Modbus registers in the x70 SCADAPack. Nor are the inputs of a Write block inherently tied to Modbus registers in the x70 SCADAPack. Instead the source of a Write, or destination of a Read, is an internal variable or array.
If you need for some reason to have these internal varaibles/arrays tied to a Modbus address you'd create an object in RemoteConnect of the appropriate type, make sure it's the correct logic variable type, then on its Modbus tab you'd enter a Modbus register #. e.g. if you created an object called Tank_Level and assigned it a logic variable type of T_SPx70_Real, you'd use Tank_Level.value.
Joel Weder
MQuin777
Ensign MQuin777
Ensign
Posted: ‎2023-03-17 04:25 PM
Thanks for clearing that up for me.  I’ll try it out and let you know.  I appreciate the help!
